okkie
Nov 26 2009, 01:21 PM
Has anyone on the board removed their 914's fenders without destroying them? What is the procedure and possible pitfalls I need to watch for? We don't have parts cars all over the country here, so they are valuable to us.
Okkie
jmill
Nov 26 2009, 01:33 PM
You have to drill out the spot welds, split the seam and do some cutting. There is no easy way. If your cutting a parts car you'll want to cut more than you would need for a repair. Here's a picture of my front passenger fender drilled out at the spot welds and cut near the cowl.
If your chopping up a parts car you might want to quarter the car up to be sure you have everything you would need for a repair on any corner of the car.
r_towle
Nov 26 2009, 06:20 PM
remove the undercoating near the passenger compartment and you will see the other seams that need to be removed.
there is a simple flange that holds the fender vertically...just cut that flange off the car.
Then you can drill the spot welds out once it is off the car, and weld a new L shaped flange back on the inner fender.
Clean all the undercoating and seam sealer out....you will see what holds it....its not that hard.
RIch
