I have a '73, 2.0, with FI that has a battery drain. Using my multimeter, I have a 57 mA drain at the battery. By removing fuses, I have isolated it to fuse #11 which supplies power to the interior light and the emergency flashers.
Fuse 11 has three wires converging to a single spade connector. When I separated the wires, I found that the smaller black/red wire accounts for about 53 mA of the current. That smaller wire is the power wire at the interior light - I confirmed the continuity with the multimeter. The drain is at that wire even if it is disconnected from the light switch. What now?
Does this wire go directly from the fuse to the light? I tried to read the circuit in my Haynes manual but it makes no sense. The diagram shows it going to the buzzer but I don't have a buzzer (at least I don't think I have a buzzer). If I have a buzzer, where the heck is it? The wires under the passenger seat are disconnected and there is no buzzer under there. The wires have been disconnected since I got it and the interior light has always worked and until now I did not have a power drain.
For now, I have disconnected the interior light so I don't drain my battery but I would like to have a working light.
Thanks.
Warrenoliver
