QUOTE(type47 @ Nov 28 2009, 02:32 PM)
I bet that's for the oil temperature sender, AKA, "taco plate". Do you have an oil temp gauge either in a console or combo gauge? If not, I think it's for the taco sender. On cars equipped with oil temp gauge, a green wire goes from the "telethermometer" sensor (in the oil sump/taco) across the engine mount bar then up through the same hole with grommet that the throttle cable goes through the engine tin. It's then connected to the connector you show in the pix.
It should be a green with black stripe for the oil temp. sender to the gauge.
