QUOTE(detoxcowboy @ Nov 28 2009, 03:15 PM)
I wish I could hear when you pull the headlight switch, you say motor is good, relay is good, but it will not come up? The passenger side only? I had an accident on that side and it was directly into the head light? The motor and relay are over kil and hardly ever fail, never seen the motor fail and the relays from there never ever fault, 1 in a 1,000,000,000. But mine would not come up either, adjustment is what I think you need. There is a U-Clip on the reverse that has a stop bolt, if your hitting that not dead center it will not rise, what you need to do is loosen the pivots, a 2 sided pivot from the fender well, and the 3 sided from the front trunk, and re allighn, but if when you pull the switch you do not hear a blocking then maybe your motor is failed, it is a huge motor that rarely gets used and is huge for its purpose. Easy to to get blocked though and strong enough to clip a finger.. Check the wiring too.
Thanks, the motor will go up and down, but not up with the switch comand, so the motor is working in my opinion, right? As far as the adjustment I can give it a try, bit not sure what I am adjusting it to. I understand the location of the 5 pivots you are referring to, but thought they were only to fine tune the position of the headlight lid? The lid is position is great. This happened to me two years ago and fixed itself before I had to do anything. Go figure.
