QUOTE(kpfoten @ Nov 29 2009, 07:52 AM)
Thanks guys,
Dave--the plastic lines are the amber ones that come through the tunnel, which (ideally) should be replaced with the stainless ones. I had my LED headlamp on it and I could wiggle the hose from the filter to the pump and noticed some large bubbles backfeeding.
I will check the fuel pressure and go from there. The pump itself does run. I believe the pump has been hacked into once before to repair of possibly the check-valve. (according to the PO who sold me in the injection system). I have a new pump on the shelf!
There's no check valve in the stock pump. You might be thinking of the over-pressure relief valve. The relief valve is located inside the little crimped-on metallic cap, about the size of the tip of your little finger.
That valve isn't designed to be serviced. If your previous owner opened it up, he probably wasn't able to crimp it back together properly and it's likely bleeding off pressurized fuel back to the return fitting on the tank.
