nebreitling
Mar 19 2004, 11:15 AM
i installed my new ERHeader yesterday, and was able to tie most cables away from it (after nearly burning through a parking brake cable!). However, i cannot find a way to route the metal clutch cable tube such that it does not make contact with the header in at least one place. is this a problem, or is this precisely what the metal tube is supposed to do; i.e. work as a heat shield?
thx, nate
Dave_Darling
Mar 19 2004, 12:12 PM
The stock clutch cable does not have a metal tube around it, except inside the center tunnel. There is metal inside of the sheath, but it is not enough to protect the cable from direct contact with a header.
It is possible this is an add-on heat shield. No idea on how well it would work.
--DD
nebreitling
Mar 19 2004, 01:39 PM
thank you for your reply, dave.
this is what i'm talking about: the metal tube carrying the clutch cable running through the center (is this the same tube as is in the center tunel?). also note top left, where i burned the rubber sheath of the parking brake. still works fine.
also note my spotless undercarriage...
any more thoughts? i can't find a place that would keep the clutch cable-tube-thing away from where the pipes begin to merge toward the collector. mucho apprecciated.
n
nebreitling
Mar 19 2004, 01:40 PM
sorry, pic
Brad Roberts
Mar 19 2004, 01:47 PM
N,
I'll show you what we use next time you are in the shop.
B
lapuwali
That's not stock. Someone added that, perhaps for the very reason you're asking this question.
Brad Roberts
Mar 19 2004, 02:00 PM
Um.. the owner of the car "Neil" installed the header and quickly found out it burns stock clutch cables. He installed the conduit.
I use a small metal loom holder and place it over the cable housing and bolt it down to a "tab" hanging off the block. It keeps the housing form melting and causing your cable to stick..
B
cgnj
Mar 19 2004, 07:33 PM
Brad,
Is this loom something that is commerically available or should I see you. My header is on the way.
Carlos
nebreitling
Mar 19 2004, 07:46 PM
QUOTE(Brad Roberts @ Mar 19 2004, 12:00 PM)
this is exactly what i was hoping to do, but i can't find a well-positioned bolt/tab/whatever to hang the loom from.
the way i have the cables arranged as of now seems OK, but i'm still interested in your idea, brad.
oh, and btw,
that header/muffler sounds fucking awesome (it also wakes up the engine more than a bit!)
carlos, the loom should be pretty easy to fabricate yourself. if i go this route i'll post pictures of my solution.
BGman
Mar 19 2004, 08:10 PM
On my 75, there is a small "tab" on the bottom of the oil pan. I am not sure what it was originally intended to be used for- but i drilled in and tapped it to accept an (approx) 6" piece of all-thread. Using this alltherad as a stiff hanger, I installed a clamp at the end to secure both cables away from the exhaust.
Actually, a small part of the clutch cable does touch the edge of one of the headers- and I wrapped it with cloth braided hose. The header is hot enough to scorch the braided hose, but not to melt through it.
-g
nebreitling
Mar 19 2004, 08:43 PM
QUOTE(BGman @ Mar 19 2004, 06:10 PM)
which tab? got a pic?
Brad Roberts
Mar 20 2004, 10:08 AM
Neil,
it is a casting tab on the bottom of the block. It held the warm air guide in place. It is tapped for a M5 bolt.
I'll try to remember to get a pic. I have showed this in the past.
B
bperry
Mar 22 2004, 12:43 AM
Are these headers from Eurorace/European Racing?
Any pictures of the Muffler supplied?
What is their current contact information?
Telephone #/Web page?
Thanks,
--- Bill
nebreitling
Mar 22 2004, 01:52 AM
ordered from HPH
http://www.highperformancehouse.com/there are a few other options as well, brad can fill you in. i must say it is a very noticeable improvement in performance.
