Howdy All,
My tunnel has a few dents. It looks like the PO hit a rock and the car bounced in a few spots on the rock as it went over. I see 2 areas, maybe 3 that could be repaired... I say could because the car drove fine. The shift tunnel wasnt impacted (it shifted fine - Is in under these dents?) and it seems like everything else in the tunnel moved nicely or wasnt impacted. Can I straighten them out from the bottom? Drill a hole, put a bolt through it, put a nut and a washer on the inside and then pull it out?
Take a look. I could use some advice. You cant see the dents from inside the cab.
Eric
