I am willing to GIVE you my Hayabusa for doing some work on my Porsche.
the value of the Hayabusa is between $5000-$6000.
I have a list that you must do to be given my Hayabusa.
--Fix front fender has it was in minor fender bender (i have fender if needed)
--Sand, paint and replace front bumper and valance (i have bumper and valance)
--Replace fog lights (i have fog lights)
--Recover bolsters (black) and cushions and back inserts with yellow plaid ($900 at AA) BUT you can use your own upholstery guy if you want i dont care how just as long as it is a good job
--Purchase and replace carpet (the cheap black loop carpet is fine)
--Purchase and replace a bunch of rubber (about $500 from mikey 914)
--Pull the motor clean it up a little (degrease, paint & seal if needed)
--Repair some surface rust spots (cali car, i dont think anything is major so no welding or cutting... IF WELDING OR CUTTING IS REQUIRED I DONT EXPECT THAT TO BE INCLUDED UNLESS SOMETHING VERY MINOR)
--While motor is out base coat and clear coat the engine compartment and rest of car
--Purchase and install electronic distributor with centrifugal advance ($150)
--Put motor back in, adjust the valves and get it to run right (when warms up it runs bad)
--Other minor things as we go are negotiable BUT i dont anticipate much
By my INEXPERIENCED ESTIMATION
-Interior $900
-Carpet $150
-Rubber $500
-Base coat clear coat $500
-Distributor $150
$2200 for parts and your labor
I AM ALSO NEGOTIABLE
