QUOTE(Dr Evil @ Dec 2 2009, 12:37 PM)
Regarding muriatic acid (found at your local pool store), which is HCl, I would recommend phosphoric acid instead. It is less of a PITA to work with and turns the rust in to a sturdy black oxide instead. HCl eats away at the good steel as well. H2PO4 does not do as bad. If you want to know where to get the phosphoric acid, it is the key ingredient in most all rust converters; Ospho (a favorite), Naval jelly, Rust-mort, etc. I used Ospho on the outside of the cutter I was on in the Coast Guard. It proved itself in that environment.
thanks guys, i think i'm gonna stay away from the acids. put in the time and hand sand then use a rust converter, it's only on the inside mounts of the stabalizer bar, not visable really, just don't want to but it back with any rust if possible.
hey doc, you ever coming up to the big city? leo is supposed to bring the brood in to the restaurant soon, you and noel can crash here. no real car work , just food and drink
