jsayre914
Dec 1 2009, 11:00 AM
Car is running great, still chirps a little, but no problems. 1.8 L w/ L-jet took off the heads and cleaned them up. New stock mm pistons and cylenders. New head gaskets, intake gaskets runner boots all fuel lines replaced all vacume hose replaced. Fuel injectors cleaned (cruzin) new fuel filter air filtre, new plugs and wires. Pertronix.Set valves ETC. ETC.
so 4 weeks later (today) I do a compression test. Car was warmed up, battery fully charged, pulled all plugs and held down gas pedal.....
1. 90
2. 110
3. 100
4. 120
I checked 2 times
jsayre914
Dec 1 2009, 11:11 AM
here are the plugs if yr interested..
VaccaRabite
Dec 1 2009, 11:17 AM
Not possible, unless your cylinders were out of round, your rings have not seated or you have some sort of massive head leak. You are doing something wrong.
Try this.
When the engine is dead cold, adjust your valves.
Get the engine warm and find a quiet road. From rolling in second, stomp the gas and take it up to redline. Lift off and let the car coast back down to rolling idle, and do this routine twice more. Thats what Jake says to do to seat the rings.
When you get back home, check your chamber pressure again.
Zach
VaccaRabite
Dec 1 2009, 11:22 AM
Also, unless you have pulled the plugs out whlie the car was hot under load, Rich and Jake have both advised me the reading plugs is useless. You are just reading them at idle, not under load.
From MD going north up 83, hitt the ramp to the rest stop just before exit 4, and shut down the motor and coast up the ramp to stop. That way you won't have ANY idle messing thing up when you pull the plugs to read them.
That said, 1, 2, 4 look rich to me.
Zach
Dr Evil
Dec 1 2009, 11:28 AM
Gee, did someone say your rings not seated?
Dec 1 2009, 12:08 PM
QUOTE(Vacca Rabite @ Dec 1 2009, 09:22 AM)
Back in my dirt bike racing days, we would cut the ignition (panic button) under full throttle, then stop and check the plugs.
Anything other than load won't give you any good plug readings ...
Andy
yeahmag
Dec 1 2009, 12:12 PM
If it's chirping, especially when cold, you have a leak at the head to cylinder sealing surface.
tat2dphreak
Dec 1 2009, 12:23 PM
when did you put the new P/Cs in?
I just don't think your engine is seated yet
4 weeks? did you put 1500 miles on in those 4 weeks? 1000?
VaccaRabite
Dec 1 2009, 03:14 PM
If Joe has been DDing the car every day, he probably has ~1500 miles on it now. His commute is ~100 miles (a day, not one way)
Zach
jsayre914
Dec 1 2009, 03:27 PM
at least 1500 miles since i put them on there
tat2dphreak
Dec 1 2009, 03:29 PM
hmm, time to bust out the borax
Mark Henry
Dec 1 2009, 03:30 PM
Head gasket.
Chirping is a dead give away, disconect the ignition crank away (cold) and listen for a whistle/squeaking noise from the lean cylinder.
VaccaRabite
Dec 1 2009, 03:33 PM
Joe, come over. We can hit it with the leak down tester and find out if its leaking from the head. I'm home tonight and free (but may take a nap if I don't hear from you).
Zach
tat2dphreak
Dec 1 2009, 03:36 PM
QUOTE(Mark Henry @ Dec 1 2009, 03:30 PM)
Head gasket.
damn I totally missed that!! that was the dead giveaway on mine too, every cylinder was leaking because the cylinder didn't fit into the head squarely... on mine the heads were not cut straight
Dr Evil
Dec 1 2009, 04:08 PM
I would have suspected as much. I told Joe just to get another used p/c so as to not mess up the (dis)harmony of his tired 1.8. He had to go and buy new ones. And then he did not break them in
I bet this is the cylinder that had the messed up piston originally. I bet the head and the register are kaka. He should stop throwing money at that low HP POS and put money into his 2056 instead
Those p/c were $300 that could have gone to cams, lifter sets, 2056 p/c, etc..... Joe is unusual
Mark Henry
Dec 1 2009, 04:27 PM
QUOTE(Dr Evil @ Dec 1 2009, 05:08 PM)
I have some nice parts for sale....I know....shameless plug ....
Dec 1 2009, 04:30 PM
QUOTE(Dr Evil @ Dec 1 2009, 02:08 PM)
Joe is unusual
Aren't we all?
r_towle
Dec 1 2009, 07:29 PM
QUOTE(Mark Henry @ Dec 1 2009, 05:27 PM)
Like what?
Rich
