QUOTE(wayne1234 @ Dec 1 2009, 01:52 PM)
Getting my engine parts together.. I noticed my case bolt that goes on passenger side near push rod tubes, isnt in the best shape and it doesn't appear to be the right washer. So I need one with washer, is this bolt indeed different It does not have a nut as this is the one that threads directly into the other case half. Thanks
I am in process of building my 1.8 ..that bolt is NLA....
as are many of the case hardware pcs....
I call it the case breaker bolt......If yah got a greasy case and miss it,
you brake the case..Try Auto Atlanta..The bolt is silver as opposed to most case bolts being black..I'm sure someone here can hook you up..AA also might have the washer..Good luck..
