I've noticed if I tighten my throttle cable at the carb linkage (pull tight and clamp), when I push in the clutch the engine revs up. I stuck a fiber optic camera in the tunnel and the clutch and throttle cable tubes look like they are stacked one above the other. the throttle cable is above the clutch cable. The tubes are not loose at all. when the clutch is pushed, it forces the throttle cable up causing the engine to rev. If I loosen the throttle cable, the engine will not rev up. It looks as though the clutch pedal "hook" and throttle cable ball are on the same horizontal plane and almost the same elevation from the floor. If I hold the throttle pedal from moving and push the clutch, the throttle cable pops off the ball in the tunnel.
Is this typical? I do have WOT with the cable loose and pedal to the floor.
