QUOTE(PRS914-6 @ Dec 3 2009, 09:51 PM)
Sorry, the friction difference between two new cables, installed properly would be very minimal. The problem is elsewhere.
Well, you're wrong about that. The problem was in the cable. Period. I didn't arrive at this conclusion lightly. I chased this problem for the better part of a year. I went through every piece of the brake system. New cables, new pads, rebuilt calipers, close attention to pad clearance, cable routing, and force balance position. The problem was only resolved after I lubricated the cable.
While you might feel a slight difference by hand, the amount of leverage applied with the handle is a lot.
At least here you're correct -- the handle has a large mechanical advantage and can generate large tension force in the cable. But that's exactly the problem -- tension force in a straight cable turns into a normal force when the cable is bent, loading the inner cable against the housing. Refer back to any high school physics text -- friction force is proportional to normal force.
Crawl underneath a pickup and you will see tons of vehicles with one side WAY longer than the other without issue. Most cables are teflon lined and have minimal friction if routed smoothly. Mine slide easlily with the bends.
The debate is not whether the asymmetric cables have dissimilar friction. They do. The debate here is really whether the force mismatch is large enough to cause actuation problems.
In my system, the friction force caused actuation problems. Lubricating the cable reduced the friction enough for acceptable actuation. It'll never be perfect as long as the cables differ, but it's a substantial improvement.
I'm glad you don't have any actuation problems, but I'll bet your system doesn't work as well as you think it does.
The problem lies somewhere else.....not cable length
Again, you're wrong. To the extent that cable length increases internal friction, then it DOES play a role.
Disconnect them at the caliper and have someone pull the handle. Do the cables come back easily?
Yeah, I've been through this. Disconnecting the cable removes the tension force, thus removing the normal force and reducing friction. Sorry, but this is not a valid test for a loaded system.
Cheap aftermarket cables?
Maybe? Purchased from Pelican. I don't recall if they're OE or not.
Cables not seated properly on the tube?
Cables are seated fine.
Calipers not working properly?
Rebuilt calipers. (Thanks, Eric.)
Cables kinked somewhere?
Factory routing.
Clamps on the cables too tight?
Clamps were removed.
Keep looking....
No need. I already found the problem.
