I was breaking down a set of IDF 40 to rebuild, and I had my camera on hand, so I decided to just take pictures of where all the jets were usually found. I know it took me a LONG time to find them the first time I tore a set of carbs down.
And, yes, these parts are FILTHY. As I said, I'm tearing them down for a rebuild.
ON TO THE PICS!
The Main Jet Stack, exploded (2 stacks per carb):
Main Gas Jet
Emulsion Tube
Main Air Correction (sorry it is blurry )
Inlet Valve (The Brass nut looking thing at the bottom of your carb fuel bowl - 1 per carb):
Idle Jet (located on the outside of the car, towards the top, just above the pump diaphram - 2 per carb)
Pump Jet (Located on top of the carb, under the carb cover - 2 per carb)
Main Venturi (2 per carb)
Aux Venturi (2 per carb)
I hope that this helps.
Any hints on making the title easier to search on?
Zach
