D1A3
Dec 4 2009, 09:24 PM
Hi Guys,
Car is out of paint and looks AWESOME!!!
I need to refinish my targa top becuase there is an area that the finish has flaked off. What is the best product or process to reproduce the factory finish?
I talked to my paint guy tonight and he says everything he is used t using is a very uniform finish and the factory finish is way too random for any products he is currently using in the shop.
Ideas?
PS: Pics to come in the coming days as we get it back together!
iamchappy
Dec 4 2009, 10:00 PM
i've had great results using truck bed liner sprayed out of my Wagner power painter, after it dries i rub it down with a scotchbrite pad, wash off the dust and use some mothers back to black and let it dull back naturally.
Spoke
Dec 4 2009, 11:33 PM
I've used Rustoleum Hammered paint. It has a similar texture as the targa but does have a relatively glossy finish.
Joe Owensby
Dec 5 2009, 09:42 AM
I completely refinished my top, as it had a hole in it from a tree limb that had fallen on it. After fiberglassing the hole and sanding it to the shape of the top, I had a fairly smooth top. So, I just sanded the entire top smooeh. I then used truck bed lliner material, that I rolled on with a paint roller. This gave almost the same bumpy texture as the factory finish. I don't remember, but I think the truck liner was glossy, so I sprayed over it with a semi gloss paint or bumper paint. This gave almost the same appearance as original. Two years ago, and still looks good. JoeO
charliew
Dec 5 2009, 10:18 AM
Back in the 70's or so they had a fake vinyl top paint that looked pretty much like whats on the 914. You might check it out at a real auto paint store and see what they have. Also I bet George at AA is using something on his cars.
sean_v8_914
Dec 5 2009, 10:54 AM
U-Poly Gravitex with Gravitex spray aplicator. dries satin black with similar texture. texture grain is easy to control.
http://www.tcpglobal.com/detailsupplydepot/dsd18.aspx
sean_v8_914
Dec 5 2009, 10:58 AM
just ignore the debris. texture is difficult to capture on camera
zonedoubt
Dec 5 2009, 12:09 PM
I wonder if something like this would work:
http://www.dominionsureseal.com/productsde...95&catid=31I used the aerosol on spoiler and valance and it gives a "schutz"-like finish.
charliew
Dec 5 2009, 12:17 PM
Most undercoats will weather pretty bad if they aren't overcoated with a clear topcoat that is a semigloss I would think.
