QUOTE(ClayPerrine @ Dec 6 2009, 12:47 PM)
Do NOT ditch the charcoal canister.
If you do, you will end up smelling gas inside your car, and you will make more pollution. Frankly, it is a small amount of weight, it takes absolutely NO horsepower from the engine, and it helps the environment. Please hook it back up.
Now, to answer your question...
On a 74 1.8L, the charcoal canister mounted either on the battery tray or the back wall of the engine compartment. One of the big lines comes off the fan and connects to the side of the canister that has the small line fitting. The other big line attaches to the bottom of the air cleaner housing. The small line hooks to the plastic line by the fuel lines.
thanks, i will try and find evidence of the original spot as it was removed when i bought the car.
i also noticed not a single pic of a 74 1.8 engine bay in the forums..wondering if this was not a popular model that year or perhaps they arent good candidates for restore...just thinking out loud
thanks again for the info guys
