I have one 21mm and three 25MM five hole wheel spacers. The 21 mm spacer is from a 944 Porsche. Two of the 25 mm spacers appear to be aftermarket and the third is an OEM Porsche 930 spacer. All have been wire brushed clean. One of the 21mm spacers was buggered up around the top of the holes. I used a Dremel tool to remove any the surface where it cold interfere with wheel mounting.
$20 for the 21mm spacer and $50 for the 25mm spacers.
[s][/s][s]
