Geezer914
Dec 7 2009, 11:10 AM
Would installing a set of 140# springs be the same as adding a rear sway bar using stock springs?
charliew
Dec 7 2009, 11:27 AM
No it will be a LOT stiffer in the rear.
naro914
Dec 7 2009, 02:48 PM
springs and sway bars do very different things. In ultra simple terms, springs affect the stiffness at that particular corner, sway bars affect how each corner handles with relation to the other. Sway bars do not really affect the ride at all in a straight line, springs do.
jmill
Dec 7 2009, 03:26 PM
Installing the anti sway bar will affect body roll. Beefier springs will make it a bit more difficult to roll just because they're stiffer. Keep in mind that you will trade ride quality for stiffness. Really, to get it all right, you need to match your springs with your shocks and sway bar. They all have a piece in your cornering ability. Too stiff will make it tail happy.
jhadler
Dec 7 2009, 05:05 PM
Sway bars work by coupling the left and right suspension through a torsion spring. You loose some degree of independence of the suspension as a result. This is not necessarily a bad thing,but it is worth noting. On rougher surfaces, the two wheels will not respond with complete independence.
Too much spring can be as bad as too much bar. Too much bar, and you couple the left and right sides so much that compression of the outboard suspension lifts the inboard wheel. This can possibly result in undesired wheel spin depending on how the rest of the suspension is set up.
Adding more spring, or more bar, will reduce your understeer and help the car rotate better. Too much though, and you just spin...
-Josh2
sean_v8_914
Dec 8 2009, 08:38 AM
rear sway bar is typically reserved for more agresive non stock set ups at the hands of an experienced skilled driver. I know many here will argue this but evaluate teh source of a comment to determine validity....very few great handling 914s have teh rear bar connected. LSD, a $3000 option, and rear bar work well together.
for suspension setup think balance, weight transfer management. it is not wise to greatly stiffen one end and not the other.
those 140s will improve cornering, wil work with stock front torsions but wil need a front bar to balance out the 140s in teh rear.
it would be best for us to know a little bit about you and your desired driving style. How will you use teh car? what shocks do you want to run? tires? competition? AX? street/ AX?
sean_v8_914
Dec 8 2009, 08:44 AM
OT: Bob, I enjoyed that off track adventure shot of Papa Smurf
naro914
Dec 8 2009, 12:08 PM
sean,
avatar updated
sean_v8_914
Dec 8 2009, 06:50 PM
sweet. did everything turn out OK after your off-track excursion?
naro914
Dec 8 2009, 08:14 PM
oh yeah. I never slowed down. and didn't realize I cracked the front splitter until later.
It's turn 1 at VIR. Went a little hot into the turn, and came through a bit wide... oops... the fact that someone got a picture is amazing..
r_towle
Dec 8 2009, 08:16 PM
Geezer, what are you trying to accomplish? That is reall the first question to ask prior to designing a good solution for suspensions.
Track? autox? Street? a combination of all of those?
Rich
sean_v8_914
Dec 9 2009, 07:11 AM
tell us more about your car so we can give you better recomendations. you dont want to end up like papa smurf up here mowing the lawn at VIR. your lucky the grouds keeper wasnt union.
naro914
Dec 9 2009, 07:26 AM
QUOTE(sean_v8_914 @ Dec 9 2009, 08:11 AM)
Wow...harsh! Actually, the suspension on Papa Smurf is about as good of a set up as you can ever get on a 914: ERP 935 front control arm set up with Fox remote resevoir shocks, 375 lb springs all around, camber boxes, reinforced trialing arms. It normally sticks like glue, I can run down a lot of car in turns and braking...
What happened at VIR is the 993 I had been chasing for about 4 laps decided to brake way too early into 1. It surprised me (I was probably about 1 foot from his bumper) so I dodged right and jabbed the brakes...but missed the brake pedal...which of course now made me go back and jab it again...waaay too late. Never spun or locked them up, just went through the turn a bit wide. I passed him going into the turn and stayed ahead all the way around.
Here are a few suspension pics (and yes, the underside of the car looks terrible)
sean_v8_914
Dec 9 2009, 07:49 AM
do you run lsd? rear bar?
that is one fine setup. although rules currently limit that type of setup for us (for now) they do allow chris' rear suspension point relocation. he says the improved geometry helps him accelerate out of corners.
if we talk about suspension set up here we can avoid a full blown thread hijacking, right
naro914
Dec 9 2009, 08:03 AM
I run in PCA GT class, so suspension is free. No lsd...yet. No rear bar. My understanding, and I'll confirm once I get lsd, is that you should run without a rear sway if you don't have lsd, run with rear sway if you do.
I ran with a rear sway forever. Then someone told me to take it off and see if it was better, which is was.
Back OT about this thread, I kind of asked a similar, but more broad question back a while ago. More of a "what should I do" in general for my other 914 - Huey. I asked here and on Pelican Parts. Here is the thread on Pelican:
http://forums.pelicanparts.com/porsche-914...tml#post4936570The post that really helped me - though I've done nothing yet on Huey - was the one from Dan:
>>21mm front torsion bars, Koni adjustables (yellows), 21 or 22 mm sway bar.
180# rear springs, Koni adjustables (or bilstein sports so you can get the car lower), no rear sway bar.
that is what I had on the Puttputt and it worked extremely well for street/AX/Track duty...
Also had this same basic suspension set up on a 914-6 with 2.7RS motor and it worked very well. This is a very old tried and true suspension setup for a track/street 914<<
sean_v8_914
Dec 9 2009, 08:20 AM
180 rear sounds light for that stiff front end...to me . I currently run 22mm hollow frt torsions, 19mm hollow Tarret front sway @ 50% (the 22mm was way too stiff) 200# rears w/ adj spring perches, no lsd, no rear bar.
those 140s will work well on Geezers street/AX ride if he has a front bar and stiffer shocks. KYBs, while a bit crude, provide additional damping required to manage the extra energy storage capacity of a stiffer spring. KYB aka "kill your back" are also fairly cheap $.
rear 140# is the cut-off point for stock front everything. you can get away a stock front bar if you add adj bar levers
rfuerst911sc
Dec 9 2009, 08:34 AM
This is an interesting post as I also have 140 lb. springs on my car but not running yet. Here is my current setup:
Stock front torsion bars
Elephant Racing polybronze bushings all 4 corners
Stock Boge front strut inserts
H&R 19mm adjustable front sway bar
Rear Koni shocks set to firm with 140 lb. springs. Stock spring perches.
No rear sway bar
Boxed swing arms with GT chassis stiffening and Engman kit.
This is a 1975 chassis with a 911 3.0 engine. Car will be street/AX/DE car. I " think " this will be a good neutral handling setup but won't know until I actually get the car running. I believe having the chassis a little soft will work out better overall but time will tell. Any thoughts on my setup ? I apologize in advance if this is a hijack of the thread.
sean_v8_914
Dec 9 2009, 08:40 AM
here's the 10Jereen 914/4 120hp-under 1700#. TTOD winner over 100+ cars. Giant slayer.
OK I read your Pelican post. Huey's front bar is way too stiff
sean_v8_914
Dec 9 2009, 09:17 AM
rfuerst911sc. your car is soft but balanced. set the rear shocks to full soft to start. all mods must be considered dynamic to the load(weight). the set up that works in a 914/4 is not allways gonna work in a heavier six. even if the six car is substantially lightened, dynamic weight transfer in the center of the car is greater as is foward weight transfer under braking. a stock six had bigger stock front torsions
start the front bar at 50%
poly bronze bushings reduce net spring rates 25-50# so your car is soft!
davesprinkle
Dec 9 2009, 09:38 AM
QUOTE(sean_v8_914 @ Dec 9 2009, 06:40 AM)
What's the story with these wheels? Widened Pedrinis? Who did it and how much? Do tell.
rfuerst911sc
Dec 9 2009, 10:51 AM
QUOTE(sean_v8_914 @ Dec 9 2009, 07:17 AM)
Sean thanks for the feedback. Yes I have the front sway bar currently set in the " middle " of the 3 locations available so I'm close to the 50% setting. I need to get the car on the road and sorted before doing some AX and I'll see what she can do.
Geezer914
Dec 9 2009, 02:11 PM
I'd like the car set up for agressive street driving. I have bilsteins front and rear. Front sway bar and Autmobile Atlanta 914-6 springs (100 lb?) on the rear. I am still putting the car back together. Is it worth adding a rear sway bar???
r_towle
Dec 9 2009, 04:25 PM
Yes, at this point in time, weld the brackets in place.
You can then choose to use it or not.
For springs, 140lb progressive springs are a nice choice...perfect for what you have in mind.
Rich
r_towle
Dec 9 2009, 04:26 PM
the car is still pissed off at you for flipping it.
Rich
QUOTE(naro914 @ Dec 9 2009, 08:26 AM)
naro914
Dec 9 2009, 04:44 PM
QUOTE(r_towle @ Dec 9 2009, 05:26 PM)
Rich
hmmm....how do you know the history of Papa Smurf? Huey is the one we flipped in Targa Newfoundland...different car. And yes, Huey is still pissed at us...never really runs right, pisses oil all over, handles bad, etc. ... needs an attitude adjustment !
r_towle
Dec 9 2009, 06:16 PM
Jealousy is the issue.
So, how did you piss off papa smurf?
You keep pulling the motor and putting in huey....that is degrading.
You leave it and take out Huey...yet another slap in the face.
Rich
naro914
Dec 9 2009, 06:58 PM
QUOTE(r_towle @ Dec 9 2009, 07:16 PM)
Rich
Ah, but we haven't taken Papa's engine out for Huey in about 18 months. Got a different engine for Huey. But you have a point:
We used to swap engines - so Papa was pissed.
We got a bigger, but weaker engine for Huey - so Huey is pissed at the lack of power
We flipped Huey - 'nuff said there.
Papa has the better suspension - Huey is pissed...
To be honest, Papa Smurf has been running perfectly for a long time - ever since we got Huey his own engine. Huey, however, is the pissy little step son with multiple personalities even though he is the only one that gets waxed and shown off... like having two kids.
naro914
Dec 9 2009, 07:01 PM
oh, and just fyi....you weren't wrong about flipping Papa...that's a whole 'nuther story....
r_towle
Dec 9 2009, 07:17 PM
ok, so enough said...you flip them...they get pissed.
Rich
sean_v8_914
Dec 9 2009, 10:16 PM
Geezer: whacha got on the front for a sway bar? those Bilsteins are great multi purpose shocks. do the 140s only is you have a front sway bar. a stock bar that can be stiffened or a 19mm bar
I strongly disagree about the rear bar
Geezer914
Dec 10 2009, 08:23 AM
Who sells progressive 140Lb springs? Or are all 140 lb springs progressive?
VaccaRabite
Dec 10 2009, 08:27 AM
I got mine from AA, about this time last year.
Zach
sean_v8_914
Dec 10 2009, 08:34 AM
