Hello all,
I need some help with a question I've had looking at various pictures of your cars and wheel setups. I see some people with spacers (slip over the lugs) and some people running adapters (bolt the adapter to the hub and bolt the wheel to the adapter). Now I'm only talking about true five lug cars and not some 4 to 5 lug adapter. I am going to need 1"+ spacer or adapter to fit my new wheels (17 x7) on my narrow body and wanted your input.
Is there a limit to how much spacer you can use? Longer lugs are needed I know.
Will tracks allow the use of adapters since they can not see the actual lugs sticking out?
Does anyone have any experience with either failing? Comming loose? The five 14mm studs seem pretty beefy.
Last question, What is the track width difference between a 914 and a 911 suspension?
Thanks
Paul
