handyher
Mar 20 2004, 10:01 AM
I am swapping engines and the tin on the one i am putting in has this strange thing attached to it (see pic) can anyone tell me if this is porsche or vw? thanks
rene
majkos
Mar 20 2004, 10:06 AM
Renee!
Can you make the pic. smaller?
Maybe a REAL cheap Turbo! Ha-ha-ha-!
ejm
Mar 20 2004, 10:14 AM
That's for intake air preheating that was used on VW's to keep throttle bodies from icing.
partsman
Mar 20 2004, 10:15 AM
What's the donor engine? I almost want to say that you probably have a 912e engine, because I seem to remember something like that on the film
Eric
TheCabinetmaker
Mar 20 2004, 10:17 AM
Lets try for a smaller pic. hope this works
majkos
Mar 20 2004, 10:18 AM
A 912 in a 914!?
Brad Roberts
Mar 20 2004, 10:29 AM
I'm pretty sure the Bus engines had them also. I run across these pieces from time to time.
B
ArtechnikA
Mar 20 2004, 11:58 AM
lawn chair. rare tropical option.
handyher
Mar 20 2004, 02:08 PM
thanks for making pic smaller haven't learned how to do that yet.
donor engine came from, a 72 914 with engine code of W stamped on it.
just curious thanks guys.
TheCabinetmaker
Mar 20 2004, 02:18 PM
W is from a 70-72 1.7L If I recall
SLITS
Mar 20 2004, 02:56 PM
The car prolly came from Siberia - that's where they would need the air pre-heater AND that's exactly what it is.
Dave_Darling
Mar 20 2004, 03:40 PM
Evidently the bits were present on the 1972 914s. I'm not sure if they were ever hooked up, though. There should be a thermostatic control on the air cleaner as well, with a lever and weight arrangement hanging off of it.
--DD
handyher
Mar 20 2004, 04:05 PM
thanks for the info. extra stuff dave darling mentioned was not there as po but a stinky ford progressive carb on it. so tomorrow donor engine goes in and hopefully no other problems will occur.
R
McMark
Mar 20 2004, 05:43 PM
Make sure to block off the hole if you're not hooking it up to something. I left the bottom piece on my tin and cut a small rectange of sheet metal to cover the hole and it had two mount holes for the cheese head screws to hold it in place.
Bleyseng
Mar 20 2004, 06:09 PM
My 72 bus with a 1700 type 4 had that to preheat the air to the dual solexs.
Geoff
