Got a set of Mueller's nifty suspension bearings, pressed the bearing tube into the trailing arm (BF threaded rod and a LOT of elbow grease), proceeded to test fit the bearings. Fits fine on the outboard end, but the inboard end won't accept the bearing.
Measured the tube ID, and found a slight oval, ie 1.318 - 1.338. The bearing OD that has to fit in there is 1.330.
So will the bearing tolerate this or am I going to have to go find a machine shop???
