Full Version: WOT: how do repair cast iron?
bfrymire
Guys,
How do you fix cast iron? Epoxy? Some other method? My g/f daughter ran over the xmas tree stand, and it's one of those nice vintage kind of stand. smile.gif
Need some help here!
-- brett
racunniff
QUOTE(bfrymire @ Dec 13 2009, 06:33 PM) *
Guys,
-- brett
Cast iron can be welded (kind-of) - see http://www.lincolnelectric.com/knowledge/a...ironpreheat.asp
Or you can go with JB Weld (epoxy)
Mike Bellis
used to fix cast iron exhaust with brass brazing.
rick 918-S
Pre heat it with an oxy acetylene torch and use an arc welder with nickel rod.
Elliot Cannon
QUOTE(rick 918-S @ Dec 13 2009, 06:05 PM) *
That's what I learned in my welding class for what it's worth.
bfrymire
Thanks everyone. Can I use a wirefeed welder? I have a propane torch to pre-heat. If not, I Can use JB weld.
thanks!
-- brett
jea69
QUOTE(bfrymire @ Dec 14 2009, 04:55 AM) *
thanks!
-- brett
if the cast iron is of good quality you could make it last over x mass with migweld,
but it has to be clean and rustfree. best is to use brass and map gas. just make sure to smooth out all sharp corners ,or you burn the brass and make a crispy connection. make the ends look like this: U and not like V
Wilhelm
Tig brazing is easy and strong on cast iron.
Wilhelm
Just recalled a link that describes a typical repair:
Tig Brazing Cast Iron
