was trying to jump pin 13 and 87 and having no luck, nothing was happening.
What were you trying to do by doing this? Were you trying to get your fuel pump to run?
I'm not sure about your pin terminology, but it would seem that you may have jumpered something you shouldn't have.
Do you have a volt meter? Get one.
If you are trying to get the fuel pump to run you need to provide the fuel pump with 2 things to get it to run (+12v and Ground)
Get a wiring diagram for your year /engine vehicle.
At the Relay board in the engine compartment, there are two harnesses. One is a 14 pin and one is a 12 pin.
On the 14-pin connector, pin 14 is +12v. It is fed directly from the battery (no fuses). When the connector is plugged into the relay board, this terminal supplies (+12v) to a fuse and then terminal #30 of all three relays.
The fuel pump power feed is pin 13 on the 14-pin connector. If you want to ONLY check the fuel pump wiring, then you would UNPLUG te 14-pin connector and try the following:
1. Check pin 13 for continuity with ground (is it shorted to ground?) There should be some resistance measured through the wire to ground, but is should NOT be close to 0 Ohms. While the resistance should not be 0 Ohms, it should not be totally open circuit either. An open circuit or infinate Ohms would suggest a broken wire. (the wire could be broken in the power feed or the ground) Check the pump wiring at the pump for ground. The brown wire should have 0 ohms when checked to ground. If the pump has a good ground, then the power feed (Black/Red) wire may be broken.
2. If pin 13 is shorted to ground, you must find and repair the short.
3. Check pin 14 for +12v with your volt meter. (Red lead on pin 14, Black lead on ground) If not, find and repair problem.
4. If you have voltage on pin 14 then briefly jumper pin 13 and pin 14. The pump should run briefly. If not then you may have a bad pump.
5. Remove the plug at the pump and wire it to a 12v test light or your voltmeter. Once it is wired, then briefly jumper pins 13 and 14. The light should light up (or the voltmeter should indicate voltage while pins 13 and 14 are jumpered).
6. If in the previous step, the light lit or the voltmeter showed voltage, your pump is bad and you need to replace it.
As far as your smoked wires goes, It is hard to say what you did without being there. I would suggest removing any jumpers you attempted to place and start working the problem with a clean slate. A good wiring diagram is probably the most important thing you could use right now. The second would be a good voltmeter/ohmmeter, and the third thing would be patience and the last thing would be persistance....
Good luck!
