proto31
Dec 16 2009, 12:51 AM
I need a decent steering column from a 1970 4 cylinder, it needs to be a 12 pin type, apparently they went to a 14 pin in 1971. Let me know what you've got.
Thanks,
Dan
914Sixer
Dec 16 2009, 01:32 PM
Dan,
Do you need just the plug?
proto31
Dec 16 2009, 06:13 PM
QUOTE(914Sixer @ Dec 16 2009, 11:32 AM)
Dan,
Hey Mark, I need the entire steering column. The last thing I need to get my car started.
Dan
914Sixer
Dec 16 2009, 07:10 PM
Check over on thesamba.com. The column is the same a the 70 Beetle.
bdstone914
Dec 16 2009, 11:01 PM
QUOTE(proto31 @ Dec 16 2009, 04:13 PM)
Dan,
Dan
If they are the same as a VW Bettle there are many of them in local Pick a Part yards.
Do you need the housing complete with turn signal switch? I think the 70 had the wiper switch on the dash, Right?
Bruce
proto31
Dec 17 2009, 10:45 AM
Dan
[/quote]
Bruce
[/quote]
I need it complete with the housing and turn signal switch, the wiper switch was on the dash. I didn't think that the VW beetle column was the same, the 914 version had it's own 914 part number.
914devotion
Dec 17 2009, 11:20 PM
[quote name='proto31' date='Dec 17 2009, 08:45 AM' post='1251868']
Dan
[/quote]
Bruce
[/quote]
[/quote]
I have a wiper washer squirt switch that goes on the right side, and the turn signal switch that sits on the left side if you want.
OU8AVW
Dec 18 2009, 08:13 AM
How about a Karmann Ghia unit. That's my plan on my 71. It's almost exactly the same. At least I can't tell any diff.....
914werke
Dec 18 2009, 08:27 AM
Pm sent
914Sixer
Dec 18 2009, 09:27 AM
My bad. It is the KG unit not the Beetle.
