QUOTE(Spoke @ Dec 19 2009, 06:51 AM)
Wow, that's some clean metal. How did you get it so clean?
I've done seam welding on places where I'm doing rust repair. The question about seam welding on the shock tower is whether the spot welds done are a weak point in the structure or not.
= ) I am fairly anal and have more time than sense... I used a wire brush on a grinder and just stuck at it until it was all gone. I will get the heater tube corners done and send some pictures of those too.
The welds all look good, but wouldnt a weld along the seam just make it even stronger? Doesnt Patrick Motor sports weld the seams in the rear end? Just have it 100% apart and on a rotisserie and want to make sure I do all the stuff I can before I paint it and put it back together.
How much welding should be done? How much sealer stripping should be done? LOL Good questions I know.
Eric
