Cevan
Dec 19 2009, 08:53 PM
I've got the oil galley plugs out (the 2 by the oil cooler, the 2 by the flywheel on the same case half, and the one by the flywheel on the other case half). One came out real easy btw. I wonder if that one would have let go at some point.
In order to get my threaded plugs flush, I need to have the tap about 3/4 inch into the hole. Before I start drilling in that far, does this sound right? The flywheel galleys look like I could go in that far but the two by the oil cooler don't.
Here is the tap I'm using.
Cevan
Dec 20 2009, 07:39 AM
Based on what I could find on the internet, the basic size of the pipe tap occurs about 12 threads from the front of the tap, which by my calculation is 12/18th of an inch. I confirmed this with a caliper.
Based on the drill bit having a point, I would need to drill into the case 12/18th of an inch plus the length of the tip, which is probably over 3/4" in total. Is this too far to drill? If so, I'm thinking I could drill in 1/2" and run the tap in 1/2", then grind some off the front of the tap so that I can get to that 12th thread.
Am I over thinking this? I just don't want to ruin the case.
Mark Henry
Dec 20 2009, 07:50 AM
Flywheel side #1 you will tap a bit into/past the one cam feed galley, so you have to be sure the plug won't go in so deep as to block the passage. #1 has to be in flush to clear the flywheel.
Fan side (and the other plugs) it's OK to leave the plugs a bit proud.
Cevan
Dec 20 2009, 08:28 AM
Which one is the #1 plug on the flywheel side?
I still don't know far can I drill into the case or whether I need to grind down the tap.
GeorgeRud
Dec 20 2009, 10:09 AM
You might want to consult with the fellow at the machine shop. I don't know how easy it would be to grind down a tap.
Jake Raby may have the best answer to your question.
enikolayev
Jan 30 2010, 08:43 PM
37/64" drill bit will make tapping easier.
914Sixer
Jan 30 2010, 10:21 PM
I used TWO taps. One was cut in half to keep from going too deep and the other was used to start the threading with. Use lots of cutting oil.
dangrouche
Jan 31 2010, 02:10 AM
I documented my galley plug install pretty well, see the last set of pics towards page two, sorry i did not count the threads, but see my pics and it can give you and idea. I used Raby's kit.
http://www.914club.com/bbs2/index.php?show...20out&st=20
