I'd like this out of my garage, so I'm trying to sell the entire engine for local pick-up before parting it out.
This is the 1.8L engine that I'm replacing with a 2.0 build. This engine was rebuilt in 2001 by the previous owner. I have several receipts but only enough to tell me that cylinders were honed and cylinder head work was done - no details. Receipts are from Soren Anderson of Santa Rosa, CA. I also know that the previous owner installed hydraulic lifters instead of solid lifters (I know..).
The engine ran okay when I had the car running. The issues were that the one of the hydraulic lifters never wanted to fill. Also, I've had fuel injection issues with this car, and the engine has been run really rich. There was gas in the oil, so I'll assume that decreased the lubricating properties of the oil. (I'm replacing major FI components with good used...)
The engine does run, and has for a few thousand miles since the rebuild, but I would consider this a "core" for a project build... From what I can see, there are no broken fins on the cylinders, and the heads were "done" just a few thousand miles ago, so perhaps less work ($$$) would be required on the heads now. The only things missing from this engine are the valve covers.
