Brad and I had a great conversation this last week. Here is what is going to happen to the design...
1. Material will be added to go over the top of each side. This will be formed and rosette holes will be added to this section.
2. I have designed this to stop at the heater tube in front, but can make this run to the front if there is enough interset.
3. I can add a form at the bottom in front of the cross support. But if you have looked at this area you should know that the floor pan does not run in a straight line from front to cross support. there is a _/ type of jog and near the front well the floorpan has a slight incline.
4. The rear piece can have a form at the bottom added if there is interest.
I have a test fit piece being made to test fit the passenger side. I was hoping to have it Friday but now it looks like mid week. I would like to thank Brad for his input and words of encouragement on this.
More info when I get the test fit piece.
M
