trojanhorsepower
Mar 21 2004, 11:08 AM
OK folks,
I have gotten the shift gears out of the trans housing and all appears well. I would like to take the differential out of the housing so I can clean everything, but wanted to check here for pit falls before I got the 13mm wrench warmed up. I did a search hear last night and looked through 13 pages of threads and did not see anything really about what I am planning. I also checked pelican and did not find much. Remember I don’t want to take the diff apart I just want it out of the case.
Thanks again
-Pete
Bleyseng
Mar 21 2004, 07:13 PM
Go ahead and take it out but put it back in with new seals esp the drive seals.
Geoff
Red-Beard
Mar 21 2004, 07:52 PM
Just remember that when you put it back in, the "gear side" goes in first...
You do not want to install it 911 style or you'll have 1 forward gear and 5 reverse gears.
Ask Jake, he even took one of his cars out this way, supposedly up to 60 mph, in reverse!
A couple of things to note. Don't over tighten any of the nuts on the studs - 25 ft lbs. If you cannot acheive this, the stud has pulled out of the threads in the case and you need to re-install the stud with locktite.
All o-rings need to be replaced. All seals need to be replaced.
James
BTDT
TimT
Mar 21 2004, 08:05 PM
whats with all the transmission questions the past few days?
I guess its always the right time for some trannies to be rebuilt
trojanhorsepower
Mar 22 2004, 09:54 AM
Thanks guys
It's all apart and cleaned. Unfortuntely I found some problems while I was in there (not totaly unexpected). It looks like there is some ware on the 1st and second gear Dog teeth. I will post pics later. Also the case is cracked where the bottom starter bolt goes through. I am at work now so I will have to wait till I get home to post pics.
Thanks again
-Pete
trojanhorsepower
Mar 22 2004, 08:21 PM
I think this dog needs a dentist. What do you guys think. Too worn, or can I put in a new syncro and seals and run for a while (at least till I can save up the $750 to get one from Red Beard).
-Pete
Bleyseng
Mar 22 2004, 08:54 PM
Time for a new slider!
Geoff
