QUOTE(luvatenor @ Dec 22 2009, 04:04 AM)
Another newbie question-In adjusting the shift rod, after installing new bushings, many people say to go to the transmission end and put the transmission in either 2nd or 3rd gear, before tightening the shift lever crimp bolt. How does one know where these gears are at the transmission? Everything looks the same when I move the lever.-Thanks Rolf
Do you have the linkage installed?
With the linkage installed---select 2nd or 3rd gear and adjust for vertical alignment of shifter and the clearance on each side is OK. Tighten the bolt on the shifter and then select 4th or 5th then reverse-1st----no impact to tunnel.
If you go the search options at the top of the page----put in shift adjustment----you will find this subject--
I had this one a while back and it was shifter hitting the tuneel.
