echocanyons
Mar 21 2004, 07:32 PM
I need to remove the axel flange from the transmission to replace them with 911 type.
Is there a tool?
Red-Beard
Mar 21 2004, 07:43 PM
Use a screwdriver through one of the CV bolt hole push it through to the case web so that the flange can't rotate.
I am pretty sure it's a 19mm. If not, it's 17mm.
echocanyons
Mar 21 2004, 07:54 PM
Thanks!
Ill give it a shot
echocanyons
Mar 21 2004, 08:09 PM
What are the torque specs for the 19mm bolt on reassemble?
Red-Beard
Mar 21 2004, 08:11 PM
I'll have to look it up, but it's something like 75 or 85 ft-lbs.
James
Gint
Mar 21 2004, 08:42 PM
I pulled output flanges on a prior 914. It's a piece of cake really. I don't recall the torque spec off the top of my head though.
echocanyons
Mar 21 2004, 09:06 PM
I didnt know they were bolted on until James pointed it out.
I had to look at them again to see the bolt set back in there.
Red-Beard
Mar 21 2004, 09:07 PM
A lot of times the bolt head is covered in CV grease.
Gint
Mar 21 2004, 09:16 PM
Ahh...crud in the works. Gotcha. I didn't mean anything by my comment. In retrospect I should have just said I agree with Red-Beard.
echocanyons
Mar 21 2004, 09:19 PM
No offense taken the first time
echocanyons
Mar 21 2004, 11:40 PM
Hmmm, maybe I was thinking of 915 trans.
Do I need the 911 type flange to adapt to 911 cv's?
Will the 914 type bolt up to the 911 cv's/axles?
JWest
Mar 22 2004, 07:23 AM
QUOTE(echocanyons @ Mar 21 2004, 11:40 PM)
If you are running 108mm 911 CVs, then you can use transmission flanges from a '69 to '71 911.
echocanyons
Mar 22 2004, 11:24 AM
yup the stock flanges definitely will not work with the early( 69-71 ) 911 cv's
heres a pic the little one is the 914 part
ChrisFoley
Mar 22 2004, 04:54 PM
QUOTE(Red-Beard @ Mar 21 2004, 09:11 PM)
James
That much torque will surely snap the bolts. Try again.
Red-Beard
Mar 22 2004, 11:16 PM
Yup - 25-30 ft-lbs...
