I finally got round to installing my SS heat exchangers, and managed to pull an exhaust stud. In fact the stud was in a helicoil, and the whole coil pulled .
So, I have a 10/8M step stud I was planning to use, but the whole is is too big to give me a full bite on the 10M threads. I have maybe 2 or 3 good threads. I think I will try the install anyway, and hope that with the low torque speck it will hold at least till I really want to pull the engine for something else, but I doubt it's going to work. I could I suppose look for a 10m helicoil or Timesert, which would have larger threads, but I'm worried I might be pushing the limits of how much material I can remove if I do that (although, I suppose if that fails, I'm still just looking for a machine shop).
So, I need to find a shop to weld, drill and tap. I live in Foster City now (SF Bay Area), and haven't used a machine shop around here for nearly 10 years. Since I'd like to avoid ending up with a warped part (or worse), can anyone give me a recommendation for a nearby shop that understands these heads?
Thanks.
Gratuitous pic below (this is after I tapped for 10M).
--Steve
