ahdoman
Jan 5 2010, 12:04 PM
Sold
jim_hoyland
Jan 5 2010, 12:18 PM
oooooohhhhhh....
sixaddict
Jan 5 2010, 12:35 PM
aaaahhhhhhh!
ahdoman
Jan 5 2010, 12:42 PM
Will you guys please stop drooling on my post! I spent a lot of time polishing this thing!
Lou W
Jan 6 2010, 12:14 AM
dlo914
Jan 6 2010, 12:39 AM
QUOTE(jim_hoyland @ Jan 5 2010, 10:18 AM)
oooooohhhhhh....
Jim i think that's the next step for your 914. You've already modded everything else! Time for a power mod
tradisrad
Jan 6 2010, 09:09 AM
What is the HP output of the engine?
-Rob
ahdoman
Jan 6 2010, 10:04 AM
According to the specs in Wayne's book; 140hp.
Eric_Shea
Jan 6 2010, 10:21 AM
And... Steve is "giving" it away.
(see you at NAMM Steve?)
ahdoman
Jan 6 2010, 10:32 AM
QUOTE(Eric_Shea @ Jan 6 2010, 08:21 AM)
Yeah, I'll be there again walking the aisles with all the old burnt out rockers and the young guns that I don't recognize.
Mark Henry
Jan 7 2010, 10:17 AM
QUOTE(Eric_Shea @ Jan 6 2010, 11:21 AM)
This is a smokin' deal and a free bump.
I'd try over on the bird plus Early S boards and swap out the cooler.
Rav914
Jan 7 2010, 12:26 PM
PM sent.
jmill
Jan 7 2010, 12:44 PM
I'm real interested in this myself. The CIS would have to go. What would it take to put some carbs on that thing. I know the cams would need to be changed. Would I have to swap out the heads too?
ahdoman
Jan 7 2010, 01:49 PM
QUOTE(jmill @ Jan 7 2010, 10:44 AM)
The 2.4 CIS does not take well to carbs. The main problem is not the cams or pistons but rather that the injector is on the head not on the intake. As a result the injector hole in the head needs to be plugged which means the heads need to come off the engine to do that
In regards to eliminating the CIS; it is a very reliable system. After having both carbs and CIS I prefer the CIS. No cold start problems, better mileage and I don't think there would be a power gain on this mild of an engine.
pete-stevers
Jan 7 2010, 04:03 PM
best of luck on the sale...bump...nab it some one!!,
jmill
Jan 7 2010, 07:30 PM
I'm on the look-out for a 911/50 or 53. I haven't found one without needing some serious work or $. I assume this is a 911/91 with 8.0:1?
ahdoman
Jan 7 2010, 08:18 PM
John - Case case ser# is 6129111 which leads me to believe it is a 911/61. That reference is from Wayne's book.
koozy
Jan 8 2010, 12:33 AM
QUOTE(ahdoman @ Jan 7 2010, 11:49 AM)
PMO makes a phenolic spacer for the use of carbs on a CIS head. It covers the injector "notch" and is made specifically for this purpose. I think they were $45 when I got them last.
jcd914
Jan 8 2010, 03:45 AM
This sounds like a great engine for a great price, if there was any way I could swing the price I would be arranging to go see this engine.
I think the 2.4 CIS is a great engine for a light car. The small diameter intake runners and ports keep the intake velocity up and makes for a very drivable torque curve.
The PMO spacers are for the 74 and later CIS engines that have the injectors in the cast aluminum intake runners and only have a notch in the side of the intake port in the heads. The 2.4 has the injectors in holes machined in the heads very similar to the mechanical injected 911 engines.
Jim
koozy
Jan 8 2010, 04:07 AM
Ah, I see that now. They are press in with an O ring, and not threaded? I have used threaded plugs for the MFI holes. Maybe not the same thing?
markb
Jan 8 2010, 10:11 AM
Wish I could afford to do this. Of course then I'd have to upgrade the brakes & suspension, new wheels & tires, might as well flare it, then paint.....it's a slippery slope.
jim_hoyland
Jan 8 2010, 10:12 AM
QUOTE(dlo914 @ Jan 5 2010, 10:39 PM)
oooooohhhhhh....
I'm looking ino it. I prefer FI for starters, checking with my mechanic to see if he is up to it--the change is beyond my ability.
kconway
Jan 8 2010, 11:37 AM
Do it Jim! That would be a fantastic upgrade. Wish I could swing it.
I'm wondering if you could do this without an external oil cooler for a street car?
jim_hoyland
Jan 8 2010, 12:12 PM
QUOTE(kconway @ Jan 8 2010, 09:37 AM)
Ext oil cooler not needed for our kind of driving
jmill
Jan 8 2010, 12:35 PM
This thing is keeping me awake at night.
Somebody buy it before I have too.
ahdoman
Jan 8 2010, 01:32 PM
Kevin - I don't think the early 911's (73.5 and earlier) had external oil coolers so the only cooler was the one on the engine. I've had a couple of people tell me that they run 2.4's without an external. However, when the engine was still in the car it had an external cooler on it but it was located under the rear trunk. That's a whole lot easier to do than put one up front.
SLITS
Jan 8 2010, 02:23 PM
And, without looking at the 2.4L I have, I would say you could tap the injector holes for a plug without much problem. All you would have to do is use heavy grease on the tap to capture the shards.
Now, no one has an excuse.
But, CIS would be much preferable to the carbs anyway.
As far as running an external oil cooler, the only reason there was one on the Turd is the original 2.4L in it was running very warm (spell hot) as the engine was really tired and had a couple of pulled studs, etc. I have been told an external oil cooler on it is a good idea as flat sixes don't cool that well in the Teener configuration.
Steve, did you do the mod to the cooling baffles prior to assembly? Supposedly, that is good for 10 - 20 degrees cooler running.
Also, with addition of 914/6 exhaust you pick up a few horsepower (can you say header type exhaust) as the 911 stock is a bit restrictive.
ahdoman
Jan 8 2010, 02:54 PM
Yeah Ron, I did all the mods; cooling tin, piston squirters and oil bypass.
kconway
Jan 20 2010, 12:48 PM
Just curious...did this sell?
