mtndawg
Jan 5 2010, 11:36 PM
I need these for a 1.7L d-jet. Please PM me if you have good ones. Shane
underthetire
Jan 5 2010, 11:39 PM
I have a brand new tank screen. If your near Hayward, buggy house has them. If you want to buy mine, 8 bucks. Buggy house was 11. I ended up with 2, only need 1.
914Sixer
Jan 6 2010, 08:43 AM
Go to Autohausaz.com for a new pressure regulator $38.
tod914
Jan 6 2010, 09:00 AM
Don't forget your 0-ring gasket you'll need for the filter sock when you change it.
mtndawg
Jan 6 2010, 12:03 PM
I'll call Autohausaz.com today. Thanks tod914, where can I get the o-ring? What's the size? Do I need anything else to replace the sock?
underthetire
Jan 6 2010, 12:17 PM
QUOTE(mtndawg @ Jan 6 2010, 10:03 AM)
Metric fuel line. I thought it was a crush washer gasket (copper). Thats what AA sent me.
tod914
Jan 6 2010, 09:06 PM
PM your address and I'll send you out one. It should work fine for the sock. Just make sure you align it properly before you tighten it down. There is just enough for it to seal. There is alittle play so just be cognisant of that when you start to tighten it down. I got them at busdepot. Unfortunetly, only the smaller size ones are available there. Not sure what material it is, but it's not copper. The sock inserts in the tank, then the gasket, then the nut. You'll want the washer sealing to the nut. The sock has has a built in crush gasket. I'm not sure on the AA ones, only that the shipping will be more than the part lol.
