QUOTE(bdstone914 @ Jan 9 2010, 08:48 PM)
QUOTE(kenshapiro2002 @ Jan 8 2010, 04:40 PM)
Do you need to drop the engine to replace them?
You can buy a VW engine compartment seal for about $10 new at any VW Bug shop or online. and cut out the straight portions to use for the side seals. The VW seal is a one piece that is a large U shape.
Marks seals are the ticket.
I do not know if you can replace them with the engine in the car. It took quite a while to install them with the engine out while sitting in the engine compartment. I even had to open up the channel a bit to get them to slide in all the way. I cleaned the channels and lubed the seals with dish detergent and water.
http://cbperformance.com/catalog.asp?ProductID=759Yeah it would definitely be a lot easier to do it with the engine out. I'm currently putting mine back in. I might just have to take the hard way epsecially with my time constraint.
And for the VW seals: would they fit in the channels? They look like they wouldn't from the picture on the link you gave. If so i'll probably use that for that back seal that's different from the other 3.
