This weekend was not picture worthy.
Lots of labor but mostly unspectacular prep work for next weekend.
We scraped off all the tar from the floor-pans to get a better idea of what amount of rust might lurk underneath. They were surprisingly solid and only need a few patches.
I also removed parts of the handbrake system. We will run a metal tube next to the long and use a custom cable to simply hook the front handle to the stock splitter in the back.
I cut all the patch pieces needed to finally connect the front targa bar with the rear door jambs to get a solid, permanent connection. This should really stiffen up the center portion of the car.
We decided to change our plan of attack a bit and get the car drivable as soon as we're finished with the major metal work.
The reason being that we want to be able to find (and eliminate) any problems related to the chassis itself that would only be obvious when driving the car.
You can only test so much while it's sitting on jack-stands.
Once we feel confident about the chassis and the basic mechanics, we can switch gears and start making her look pretty.
Andy
PS: If you want to swing by, the next Limo workday will be Saturday, 03/13 at McMarks shop in Sonoma ...
