QUOTE(Wardsweb @ Jan 13 2010, 01:19 PM)
I can adjust the brakes and all is fine. I use the emergency brake and only the passenger side is holding. I adjusted the driver's side cable until it came totally out of the tube, effectively pulling on the e-brake lever at the caliper all but tight, but it still doesn't engage. I thought it was a mechanical induction. Something must be amiss inside.
Try moving the lever on the caliper with a pry bar. If it doesn't move, contact Eric Shea about a set of rebuilt calipers.
