Full Version: optima battery question
My local Costco sells the #35 for $125, local Pep boys sells #34 for $185. Will the 35 work? Thanks, Mark
tod914
35 dimensions -
Length 9 - 5/16"
Width 6-13/16"
Height 7-5/8"
Weight 31.7
34 dimensions
Length 10"
Width 6-7/8"
Height 7-13/16"
Weight 37.9
On the 34, you have to shave maybe a 1/4" or so, off the base on both sides to get it to fit in the tray.
orange914
the costco optima i bought fits great. i'm not sure of the number but i'm guessing it's the 35 as it's the only red top carried at our local costco
mike
SGB
Note the height difference if you have a rain tray...
Also, 37 lbs might be a bit of a load for an already fragile spot... sad.gif
Tom_T
QUOTE(SGB @ Jan 15 2010, 05:27 PM) *
He's saying the shorter & lighter 34 is at Costco for $60 less - sounds like a deal to me.
IMHO - Take a tape measure & the teener to Costco & check it out, & save yourself a few bucks.
tod914
35 Tom tongue.gif Sounds like a better way to go. That 34 is pretty heavy. I think the puck adapter is the 78 model to secure it to the tray. Might want to see if it also works for the 35 series.
tod914
70Sixter
I got a tiny sealed 17 pounder with brass terminals from Tire Rack made by Braille. Complete with plastic mounting bracket to mount in any position. There is an optional aluminum bracket suitable for racing.
And it did not cost $2000, less than $200.
