Full Version: Dashpad question
Is there a difference between years for the dashpad? Will a 75 fit in a 70 car without modification? Thanks, mark
914Sixer
All the dashpad are the same. The texture of the early pad is said to be different. All the tops I have seen over the years appear to be the same. I have noticed suttle differences in the texture of the ashtray pull.
kconway
Isn't the relief around the glovebox a little different early to late years?
tradisrad
If you are talking about the dash with the ash tray part they are different. The glove box relief on the 70-72(maybe to 71) is larger and your glove box will not open all the way with a 73 and later dash.
I've got a nicely recoverd '73 dash and I did not use it in my '70 car because of the glove box reilief.
QUOTE(tradisrad @ Jan 17 2010, 11:11 AM) *
I'm talking about the large vinyl covered foam pad that covers the top of the dash, not the actual metal dash.
kconway
QUOTE(mepstein @ Jan 17 2010, 08:15 AM) *
Yeah, so are we. If you look at the area where the glovebox is there is a relief in the pad to allow the glovebox door to swing up. Early to late are different size reliefs.
sixerdon
First, there are two variations of the dashpad. Early '70 - '71 and late '72 - '76. The change was when the side vents were introduced in '72 making the glove box and door smaller in width.
To answer your question, the late dashpad will fit on early dashes, but the glove box door will not open all the way causing scuffing to the relief on the underside of the dashpad. Just be careful opening the g-b door. Mine has been in place for over 10 years until I can find a quality substitute. It doesn't show unless one knows what they are looking for.
Don
Thanks all for the info.
QUOTE(sixerdon @ Jan 17 2010, 08:24 AM) *
A '75 dash-pad will not fit into a '70 car without modifications.
shades.gif Andy
sixerdon
QUOTE(SirAndy @ Jan 17 2010, 11:04 AM) *
shades.gif Andy
Not true, Andy. It has been fitted on my car without without mods. Just careful on opening door. No problem.
Don
QUOTE(sixerdon @ Jan 17 2010, 12:04 PM) *
Some people don't like to be careful ...
shades.gif Andy
70Sixter
QUOTE(sixerdon @ Jan 17 2010, 11:24 AM) *
...the late dashpad will fit on early dashes, but the glove box door will not open all the way causing scuffing to the relief on the underside of the dashpad. Just be careful opening the g-b door. Mine has been in place for over 10 years until I can find a quality substitute. It doesn't show unless one knows what they are looking for.
Same here. My glovebox door does not fully open.
I just know there is a nice early dash cover out there with my name on it!
