You are measuring endplay in the crank by the rim of the flywheel. You absolutely need the flywheel fully torqued on, just as if the engine was going to be running. This includes all bolts and washers.
if by wobble you mean that not all the bolts attaching the flywheel to the crank are installed, and it has a slight wobble - you need them all installed our your measurements are going to be worthless.
if by wobble you mean that the surface of the flywheel is not a perfectly flat surface, you are correct. That is why it is critical that you take your measurements from the same point on the flywheel, not letting it rotate at all as you tap it back in for the second reading.
And while you can use the tool w/o feeler gages, I don't trust my eyes as much as I trust the feeler. It may be an experience thing, though. Guys that have done it more this way are perfectly comfortable with it.
Zach
QUOTE(ericread @ Jan 19 2010, 11:15 AM)
As I said, I'm a bit slow...
So the design includes a slight wobble in the flywheel? And the tapping should be done after the crush washer is installed and the five center bolts are torqued?
Again, my thanks!
Eric Read
QUOTE(Vacca Rabite @ Jan 19 2010, 07:39 AM)
Bolt the tool to the case using the long silver bolt.
with a rubber mallet tap the fan end of the crank to push the flywheel back as far as it will go.it is not much, but it needs to be pushed back.
Turn the black bolt until it *just* touches the flywheel. tighten the lock nut to make sure that the black bolt does not change position. Do NOT remove the gage.
Tap the center of the flywheel with your rubber mallet to get it to move forward as far as it will go. There should now be a very small gap between the foot of the black bolt and the flywheel. Use feeler gages to measure the gap.
Be sure that you so not spin the crank as you push it back and forth. you want to be taking your measurements at the exact same point on the flywheel.
Zach
