Full Version: Engine test platform
ruddyboys
I want to make a test platform to test my engine before installing it back into the car. I have seen a few but was unable to find the post. If some one has some pics and what I need to get the engine to run I would appreciate it!
VaccaRabite
Lots of people had different ways of doing it. This is what I made and it worked really well.
IPB Image
It is plywood, with a cut out in the center where a floor jack can be rolled in. The whole platform is on casters to be moved about, and was designed so that the engine, transmission, and exhaust could be moved on the test stand under the car, raised into place and bolted in after i was done with the testing. It was designed with Foleys lifting plate in mind.
The dashboard has a button for the starter, a switch for fuel and ignition, and a tach. I did it like this so that I could run the starter without actually starting the motor, in order to build oil pressure. in the future, if I reuse it at some point (probably will with Joes 2056 build) I'd put an oil pressure light on it too. I was going to put a throttle on it, but never got around to it.
Zach
underthetire
QUOTE(ruddyboys @ Jan 19 2010, 10:59 AM) *
Call DR.EVIL. He sells cut off bell housings just for this. Makes it easy to hook up the starter !
ruddyboys
Zach. that is just what I needed, thankx!
Dr Evil
Zach's set up is nice, but more than you need. Here is what I do:
- Furniture dolly from harbor freight ($15)
- Push button starter for engine from harbor freight ($12)
- Engine/starter adapter from me ($60 shipped to lower 48)
Put engine on dolly, connect up the fuel pump (power can be had from coil + side), connect up starter, push button.
To stop the engine, remove the coil B+ lead.
Less elegant than Zach's, but cheap and effective and leaves less crap to clutter your shop after you are done wink.gif
