I thought, well the megasquirt has a decel cut function built in, that will help lean out the mixture on decel, and thats what this valve did anyway. Wrong. The decel valve I have since discovered makes shifting easier. Why you ask? Cause it allows air in once the throttle plate closes. This allows the engine to return to idle in a much slower fashion, thus not making the syncros in the tranny to work so hard. I figured this out cause my tranny will speed shift fine, but if I take my time, which I normally do, its much harder to get in gear.
