siverson
Jan 20 2010, 06:04 PM
I'm just curious...
I put new seals on my six when I restored it, it I'd say it leaks a little. Definitely not dry, but livable.
On my new [to me] 4, the seals *look* ok, but it leaks horribly. If I park outside, I can literally get puddles of water on the floor (both sides, in front and behind the seats).
-Steve
siverson
Jan 20 2010, 06:05 PM
Ooops, I messed up the poll. Oh well.
underthetire
Jan 20 2010, 06:07 PM
I think you forgot Monsoon inside the car vote.
jsayre914
Jan 20 2010, 06:08 PM
I also replaced the famous 3 part seal and the lower targa seal, the targa side seals and verticle seals and rear targa seal. (thanks Mikey.
son of gun still leaks on both sides
right where the side seals but against the big (3 part) seal.
I guess we all have to live it
Jan 20 2010, 06:26 PM
QUOTE(underthetire @ Jan 20 2010, 04:07 PM)
Custom 'drain' holes help with the puddles ...
Andy
PeeGreen 914
Jan 20 2010, 06:31 PM
Okay, mine is only dry as a bone when it rains out because it stays in my garage. But when I'm AXing and it rains I have the windows down so of course it's wet.
Porcharu
Jan 20 2010, 06:38 PM
Rear window is loose - lots of leaks and standing water under the seats. Yes it's rusted in those areas.
Steve
SLITS
Jan 20 2010, 06:39 PM
I carry a bar of soap for my bi-annual bath.
7275914911
Jan 20 2010, 06:56 PM
Drivers side would get "A Little" vote BUT Passenger side more than makes up for my "A Lot" vote...I believe it would puddle if not for the carpet?
When I'm AXing it is Monsoon since I have no windows in my early doors
KP
Pat Garvey
Jan 20 2010, 07:50 PM
Mine is a 2, that I bought new.
Never leaked a drop until 1976, when I decided the seals needed to be changed. Stupid!
I've rerplaced all seals twice since then & I still leak in a rainstorm. Course, it hasn't been in one of those since 1989. Because of that, I haven't touched my 914 with water since.
I should go into the dry cleaning business for Porsches.
Pat
Joe Owensby
Jan 20 2010, 08:52 PM
Put in a total new set of rubber from AA a few years ago. I have almost zero leaks. I do get a few drops when I open the door in the rain. Takes a little time to get everything to line up, but it is worth it to minimize leaks. I have had the car since new, and it was pretty dry when it was new also. So, the design should be pretty good. Just needs good rubber and proper alignment of the seals and also the window glass and door. I guess this is assuming the body is also straight.
JoeO
sww914
Jan 20 2010, 09:04 PM
The inside of my ears stay clean if I drive it in the rain.
VaccaRabite
Jan 20 2010, 09:49 PM
Rain is wet, so I don't let my car see it.
Zach
jd74914
Jan 20 2010, 10:34 PM
My car is surprisingly leak free. I'm consistently amazed at how little water enters when it rains (the car lives outside when I'm at school).
That said, a few weeks ago we had really strong winds which were strong enough to blow snow into the car. That was really odd.
Elliot Cannon
Jan 21 2010, 12:02 AM
Drive fast.
Don't stop.
Stay dry.
hot_shoe914
Jan 21 2010, 12:18 AM
mine leaks the same amount of oil whether it is raining or not!
Middlefour
Jan 21 2010, 02:07 AM
I always thought that if they did'nt leak you took them back to the factory to make sure they did!!!!
Here in England we get wet, errr quite often.......
siverson
Jan 21 2010, 03:50 AM
My red car just had about 0.5" puddle ON TOP of the carpet... :/
Mikey914
Jan 21 2010, 04:31 AM
QUOTE(jsayre914 @ Jan 20 2010, 04:08 PM)
Check the lower seal. Pull it out and put it back in. If it's cracked and brittle that can be the cause of leakage sometimes.
tat2dphreak
Jan 21 2010, 10:07 AM
I need seals, I can stick fingers into the cab at certain points... I just don't drive in the rain.
EdwardBlume
Jan 21 2010, 11:17 AM
I tried to winterize my former race car with tape and a cover, and all I ended up with was mold....
SLITS
Jan 21 2010, 11:18 AM
QUOTE(Elliot Cannon @ Jan 20 2010, 10:02 PM)
Drive fast.
Don't stop.
Stay dry.
Elleyott has it right. don't even need the Targa top in place. Most of you probably never owned an English Sports car. A 914, with bad seals, is dry compared to them.
In fact, England is where the wet-head movement came from (also soggy shoes, socks, etc.,)
bandjoey
Jan 21 2010, 12:22 PM
Until I Mikeysized the rubber, it leaked. I'm happy now with a dry cabin. I did have to reseal the rear window, but new seals took care of everything else. As an afterthought, I put a very small clear seal of silicone caulk around the outside rear glass, and the chrome windshield trim. So far it's tight.
jhadler
Jan 21 2010, 01:41 PM
Not a drop! Then again, it helps that it's in a garage up on jackstands...
-Josh2
al weidman
Jan 21 2010, 08:40 PM
I don't want to find out, no rust so far.
szuccaro
Jan 23 2010, 12:06 AM
no leaks because I dont drive it in the rain. :>) Steve
Heeltoe914
Jan 23 2010, 11:06 AM
Well its in the garage most of the rainny days, so not to many leaks but I have replaced evey seal.
Rod
Jan 23 2010, 12:08 PM
Mine doesn't leak at all
It is annoying though when it does have water on the roof and you drive off with the window slightly open........ at the end of the drive, all the water runs forward of the gutter in the side of the targa and if the window is slightly open, it's a perfect angle straight down from the targa, through the window and straight into the door pocket cubby hole!!!
Very annoying.
My rear trunk used to leak n the rain, but fixed that with a bit of silicone. Mine is a dry 914
QUOTE(szuccaro @ Jan 23 2010, 06:06 AM)
Love this trunk, it looks like it's trimmed in Alcantara? is it??
Sleepin
Jan 23 2010, 04:17 PM
QUOTE(SLITS @ Jan 21 2010, 10:18 AM)
Drive fast.
Don't stop.
Stay dry.
The MG's 'vert top was like a water magnet...I think you would stay drier standing outside in the rain than inside the car with the top up!
The only time my 914 leaks is when it rains.....
Usually I am driving sans top so a fast drive is in order to keep the interior dry. It is amazing how dry you can stay with the top off in the rain if you find the correct speed.
azbill
Jan 24 2010, 10:21 AM
My car never leaks. It lives in Arizona and never out in the rain.
SUNAB914
Jan 24 2010, 07:26 PM
Beautiful rear trunck above! 74 holds against leaks OK, very worrierd though when it happens. 75, only on drivers side, has to be heavy though. It can be done!
phoenixred
Jan 24 2010, 11:36 PM
I too needed rubber parts, put all except the upper & two lower targas, and the two inner door seals. I wonder what the new parts are...I think the cabin parts were all Porsche. Perfect fit, and worth the time. Prolly over 300$ easily for the less expensive seals.
My car is not anywhere near perfect margins etc. this is reflected in some near gaps here and there. definate drips off the "builtin" gutter in the top itself. If windows are cracked 1/2 inch better watch that gutter drip. default water source is pushed from the p/side rear wheel wash into the rear of the rusty floor pan.
it was quite a big surprise when I first got the car on the road. now, with basic problem areas found and work around in place.(stuffed rusty floor pan with easily manipulated ropecaulk/almost like the electrician's putty to water seal cables on service entrances.easily removed or "helped" with more putty until the real repair arrives
meanwhile this NJ car has a daily driver's life
it's great!
charliew
Jan 25 2010, 10:43 AM
I bet the rear window is loose in every 914 that has over 75k on it unless it's been resealed. One of my fieros has a loose rear window and it only has 60k on it but it was hit in the right rear quarter also at some time in it's life. I bet the 914 leaks less than a early corvette convertibile. And maybe less that a later t top one.
ppeters914
Jan 25 2010, 12:31 PM
QUOTE(Joe Owensby @ Jan 20 2010, 06:52 PM)
There's always a catch......
IronHillRestorations
Jan 25 2010, 06:06 PM
Shamless plug. This will keep the interior of your 914 dry!
Click to view attachmentClick to view attachmentI'm out of stock right now but should have a good supply in a few weeks. The material I've been using for the past 14 years is getting harder to get.
Kirmizi
Feb 1 2010, 03:40 PM
Shameless plug. This will keep the interior of your 914 dry!
One of the best investments I've made so far.
Mike
gothspeed
Feb 1 2010, 08:22 PM
QUOTE(9146986 @ Jan 25 2010, 04:06 PM)
Sell me one!!!!!!
mikerose
Feb 2 2010, 03:04 PM
Best money ever spent.
gopack
Feb 6 2010, 12:05 PM
I voted "none" because it never rains in my garage! AND when I DO get it running I will try hard to never go out in the rain!
J P Stein
Feb 6 2010, 12:18 PM
I had a 58 Vette....with a hardtop some years back. It set my standard for leaks into the interior. Bout the only place water didn't come in was from the bottom up.
