QUOTE(oldschool @ Jan 25 2010, 09:46 PM)
QUOTE(rick 918-S @ Jan 25 2010, 10:51 AM)
Still injected? Check the relay board and the fuel pump relay.
Is the engine cranknig over fine? Just no fuel pump?
Rick it seems to cranck ok but not as fast as my red car as it was when it was
running.
So it looks like the fuel pump. You can either do the troubleshooting with a meter or you can try the usual suspects. The fastest test and the most likely culprit is to replace the main power and fuel pump relays. They are the same relay as your headlights. If your headlights pop up ok take the relays from them and replace the two on the relay board.
