Haynes Manual has an image and a drawing of the tool to set them.
I think we know what to get Rich for Christmas.
Make sure the angle is in the face of the rotor as it sweeps through the pad cavity (this is a passengers side as an example). Easy way to set the angle (that is, without those pad positioners that should have come with your rebuild kits) is to draw the imaginary line in the bore and put the bottom notch in the center of this line.
This is a step you should really get right:
* Make sure you set the angles properly on the appropriate calipers (meaning left and right).
* Make sure your bleeders you want to have at the top will be at the top.
* Install the pad positioners "before" you install the pistons.
* Install the inside clip on the pad positioner first (there's 4 of them stamped in there) then seat the remaining 3.
