well the title sums it up i guess. i went and put it in hemmings so i guess i'm serious. i've owned her since 1988 and have just finished a ground up resto/mod. i have o.e. changed parts and everything can be put to stock, but with modern improvements why? i planned on keeping it forever, but as some of you may know i had a pretty severe back/spinal injury 7 years ago now. that said, i think i should find a good owner to take care of this truley unique and special mustang. (don't worry we're keeping the 914!) i know alot of us 914 guys love mustangs so get the word out! here is some pictures and the ad i made up for to post on various sites:
FOR MORE PICTURES GO TO:
http://share.shutterfly.com/share/received...=2AbMmbFo1bM3rA
s-code big block 1967 GTA mustang complete with marti report. i've owned and loved this car for 22 years! since 1988. it breaks my heart, but reasons out of my control i am putting it up for sale. it is a true, very well optioned, 99.9% rust free GTA. this original black plate california mustang has a very unique history. it had under 100,000 origanal miles before "frame off" restoration. it was only on the road until 1979. it was again put back on the road after spending 22 years in my climate controlled shop, making it a 31 year "in the barn find". the summer of 2008 it saw it's first local car show and then was used recently for my son's wedding as the "just married get away car". with less than 200 limited miles on it since it's rotisary "frame off" nut for nut restoration, nothing untouched or ignored. this mustang is as new and solid as they come. as a retired certified ford and a.s.e. master mechanic, with extensive mustang/shelby restoration experiance, i tastefully restored and upgraded it as a "resto/mod", with every intention of keeping it forever. all modifications could be put back to o.e. if so desired. this GTA has had the best of everything. contact me with any questions you may have i will do me very best to answer in detail. please enjoy the following details of the car. i have 2 HUGE files of receipts and past registration documentation. this has had no expense spared. now is a great opertunity to bid on a very unusual and rare car.
FACTORY OPTIONS:
*GTA package *deluxe interior
*s-code G.T. engine *air conditioning
*handling package *remote mirror, pass mirror
*power steering *am/8track stereo
*deluxe exterior package *upper console
*power 4 piston disc. brakes *lower console
*louvered signal hood *deluxe seats
*rear tail light fins *deluxe seat belts & shifter
*G.T. gas cap *tach., trip odo., clock opt.
*dual exhaust *brushed aluminum throughout
HISTORY:
this car came from the san jose, ca. plant and has resided in californias central valley all it's life. the weather is hot and dry, the perfect rust free inviroment. i purchased it from the previous owner who bought it with engine damage in 1979. it sat with him until 1988. he was getting married and needed to sell for finantial reasons. i was working for ford at that time so i bought every n.o.s. part i could get my hands on. raising a young family slowed the restoration, but in reality created the perfect quality control to guide it's maticulous restoration. a custom rotisary was used and EVERY nut & bolt removed. the original paint body was media blasted inside and out, exposing 99.9% rust free original metal. the ONLY rust spot on this entire car was the size of a dime. it was where the trunk drain had plugged, holding in moisture. EVERY component has been rebuilt or replaced and N.O.S. parts where used whenever possible. this GTA's underside was painted in detail while the interior was insulated with sound deadner to cut noise and improve comfort. this mustang received many touches that your typical restoration wouldn't even consider. i recently was very fortunate to have Carrol Shelby autograph it's dash! this mustang truely is a unique carrol shelby autographed,GTA. everything was done with attention to detail. this car is a blast to drive or just look at!
several years back i had a motorcycle injury prompting me to find another owner to care for this truely special vehicle with very little to do to make perfect. ford did it right on this mustang. it was motor trends 1967 "car of the year". look at all you get!
ENGINE:
s-code 390 engine, blue printed and fully balanced, polished edlebrook aluminum intake (also have "S" intake), oval "cobra air cleaner (have g.t. air cleaner base), "C.J./GT exhaust manifolds, exhaust pattern on heads drilled to accept any manifold pattern
*9.5:1 forged TRW pistons
*rings end gapped
*428 C.J. spec. camshaft
*double roller timing chain
*rotating assembly balanced
*pistons and rods individually balanced
*edlebrock aluminum dual plane intake
**O.E. "S" intake (note #1)
*oval (cobra type) air cleaner
**O.E. GT air cleaner base (note #2)
*428 C.J. windage tray
*high volume oil, fuel and water pumps
*drilled & tapped oil galley plugs
*brass freeze plugs
*new core 3 row o.e. 24" radiator
*clutch fan clutch
*all new hoses/belts
*optima "red top" battery
CHROME items:
*engine oil & trans. pans
*hood hinges
*hood latch
*fuel feed
*export brace
*shock towers
*coil
*alternator (high output)
*frame/engine underbar brace
*trans mount
*most under hood visable bolts & other misc.
*rechromed o.e. valve covers
FUEL:
**correct 4150 holley (C6OE-9510-D) with holley kit (note #3)
*rebuilt holley 4150 (C6OE-9510-N)
*all fuel hard & soft fuel lines replaced with 3/8"
*high volume fuel pump
*new 22 gallon tank
*new sending unit
TRANSMISSION:
*rebuilt H.D. C-6 (extra clutch packs)
**extra valve body (new) (note #4)
*chrome trans pan
CUSTOM BUILT:
*polished aluminum driveshaft, spicer universal joints
9" REAR END:
*rebuilt 4.11 gears, ALL bearings and seals
*o.e. 3.0 gears
**brand new trac loc posi unit, seal & timkin bearing kit, "N" case complete to build a spare bolt in center section) (note #5)
SUSPENTION & STEERING:
*progressive rate performance front springs
*progressive rate performance COMPOSITE mono rear leaf, awsome ride! (the trick set is only 18 lbs vrs. 60 lbs for steel!)
*kyb "belly" gas shocks all around
*66' shock mount used (1" taller for lowered shock travel)
*fully adjustable heim joint front AND rear matched sway bar set
*underride adjustable traction bars
*poly urathane bushings thruout
*relocated upper a-arm "shelby" modification
*boss 302 reinforced shock tower upgraded bracing
*beautiful wood trim NARDI steering wheel (italian signature series)
**original steering wheel (note #6)
*flaming river stainless tilt column
*flaming river steering gearbox
*flameing river stainless power assist
*tie rod bump steer/ackerman angle improvement kit
*h.d. billet tie rod end couplers
*p/s performance pump w/ custom high pressure hoses
EXHAUST:
*390 G.T./428 C.J. exaust manifolds
*2 1/4" aluminized pipes using o.e. bends/isolators/hangers
*flow masters
*large chrome balony tips
WHEELS/TIRES/BRAKES:
*custom built and balanced style steel rims using original style steel center sections (rechromed) and N.O.S. blue caps
*fronts: 15x7 with 225x50 bridgestone R.E. 71
*rears: 15x9.5 with 245x50 bridgestone R.E. 71
*spare o.e. style steel rim in trunk
*o.e. fully rebuilt 4 piston kelsy hayes disc.
*new rear wheel cylinders, shoes, drums & hardware
*new ALL steel lines & hoses
*new master cylinder & booster
INTERIOR:
*deluxe brushed aluminum dash, doors & upper & lower consoles
*tachometer, trip odometer and clock (w/ new quarts movement)
**Carrol Shelby autographed dash w/ doc. picture (note #7)
*nardi autographed steering wheel - imported series from japan
*flaming river brushed stainless tilt wheel column
*a/c & heater box reseal with new heater core
*upper console option
*lower console option
*deluxe shifter option
*am/8track option w/ huge collection of tapes!
*deluxe comfort weave
*fold down rear seat option
*fully adjustable performance front bucket seats
**o.e. deluxe front bucket set (note #8)
*deluxe seat belt option
*locking glove box option
* ALL new seals, headliner & carpet
LIGHTS/ELECTRIC:
*upgraded lighting
**H4 glass headlight assemblies
*G.T. fog light bar option
*turn signal in hood option
*RARE "finned aluminum" tail light fascia
*ALL new bulbs in & out
*new high output alternator
*optima red top dry cell battery
GLASS:
*factory tint, new windsheild
*rear glass lightly over tinted with "very subtle" stripe tinted in to match exterior stripe lines
**extra o.e. rear glass (note #9)
*all door/trunk/glove box lights
BODY:
*deluxe exterior package option
*ultra rare finned aluminum tail light panels, (option on option)
*stainless door gaurds and wheel trim option
*ALL new seals through out
*deluxe turn signal louvered hood
*original california black plates!
**extra o.e. rocker panels (note #10)
*G.T. pop open gas cap
PAINT:
*excellent deep finish, always garaged. apx. 200 miles since restoration.
*flame red base/clear coat, multiple coats PPG
*dual stripes (correct ford measurements) and "buried" under clear coat, lexus color- black cherry pearl (subtle red pearl in sunlight)
*underside extreemly detailed also
this mustang is a very nice, low mile, rust free example and needs little to be 100%. why pay so much more for a elinor fastback, non G.T. "S" code or any other "wanna be". you can pay much less to own the real, rare & highly optioned, black plated GTA. this time capsule turns heads. at my low reserve you will be getting much more value for your money, with great collectability.
accepting offers starting @ $45,000
buyer must arrange shipping. i will do everything possible to help make shipping pain free.
