At the top of this diagram is the relay for the rear defog window, which as i see it is connected to the 2 open posts on the relay board; In the above diagram 1 post(#86) has a yellow and red stripe wire and the other post (#87) a green wire. If I power from the switch in the dash to the yellow red stripe wire's post(#86) and then run wire from the green wire's post (#87) to my window power side and then gound the other side of the window, I am good to go? Any one know how to fog a window for testing? (Other than heavy petting at drive in movie)
