I'm thinking more and more about a smallish 6 transplant, after drooling over Ahdoman's 2.4 w/CIS, I thought I'd toy with the idea of a conversion. So, as an exploritory excercise I was wondering what I could sell my newly rebuilt 2.0 that has yet to be installed in my car. Any idea what the following package should net? Just trying to get an idea if a 6 will fit within my budget and an idea what my engine would sell for might give me an idea if its affordable.
Engine and head work was performed by EMW in Hawthorne, CA. http://www.europeanmotorworks.com/
Newly rebuilt 2.0 big bore w/FI has not been broken in yet built by European Motor Works
Balanced 96mm P’s & C’s
STD/STD balanced crank
Balanced rods stock
Case has been align bored and galley plugs replaced
Heads renewed cracks and plug holes welded and retapped, valve job
Loads of new FI parts including
+NOS ECU
+NOS MPS (tested good)
+NOS Injectors
+NOS Throttle switch
+NEW fuel pressure regulator
+New Cylinder head sensor
+New Thermo time switch
+New cold start valve
New Bowlsby FI harness, Engine harness and Alternator harness
Powdercoated Tin
Fuel pump
Spotless set of SSI HE’s
Triad Muffler (I assume this couldn't be used on a 6)
