From another thread last week. There is MB model info there but I haven't verified it.
http://www.914world.com/bbs2/index.php?showtopic=103193From that post the part numbers are...
Unless these have been superseded, I used these numbers for my 23mm master cylinder.
The (Mercedes Benz) Part number is 022.430.9301
The ATE part number is 03.2123-3402.3
You'll need the "blue" hose and 90 degree inlet pieces unless you already have them.
Note: I had to relieve (grind off) a little of the dimpled end to get it to fit behind the rack .
Not a problem and it's been in use for ~12 years. I have Wilwoods also.
_____________________________________
FYI SmartRacingProducts has a kit for the 911 but have all the bits to make it a 914 thing. I'd bet they're familiar with our application.
http://www.smartracingproducts.com/pdfcat/...heelsbrakes.pdfGood Luck
