Interesting, its looks decent and priced okay (ish) but I see it as probably not worth the effort. You are still limited to the 2D advance curve set by the bosch distributor weights. I figure if you entertain this type of mod you engine is not stock and the factory curve will only be okay.
I have been entertaining using this
http://www.autosportlabs.com/Crank fired ignition with programmable curves using Ford EDIS components. 3d spark curve based on tps or vacuum signal. A little harder to do and not as clean but more attractive for my purposes.
I think the unit you found may be very attractive for a more stockish usage.
John D
